I have been trying to solve the problem below involving a concrete anchor block subject to two equal horizontal forces. Normally I would just apply the force as a moment acting about the centroid of the concrete block which would produce a linear bearing pressure distribution at the base. Adding the self weight of the block as a compressive bearing pressure and I would then have an idea of the complete bearing pressure distribution. Am I missing something? taking moments about the centroid with the forces turned into vectors via the position vector and using the cross product only gets me so far.
Usually, these kinds of problems can be handled as a footing with P load and M overturning moment. I don't quite get those assumptions though.
The overturning moment will cause the anchor block to triangular positive and negative stresses on the soil, which can be calculated as, call this stress Q at the maximum point the end of the triangle:
$$ \Sigma M_y=0,\quad (1500+1500)5kNm=2(Q*7.5/2)_{total\ stress}*(15*1/3)_{lever\ arm}$$ $$Q=15kNm/37.5=400N$$ but this is for the 5 meters base width, therefore $$400/5=80N/m^2$$
The slope of this stress surface is $80/7.5=10.66\text{ N}$ per meter. With 0 stress at the middle of the 15m length.
So the total stress distribution is $$P_{total}=(P-80+10.7*x)Nm2$$
please check my arithmetic.
