Is it possible to reduce line-weight (thickness) of border in Solidworks sheet format. I want to reduce the thickness of the lines shown below as I find it too much thick.
$\begingroup$ Does Solidworks have a Help system? Or instructions? $\endgroup$– Solar MikeNov 20, 2020 at 18:13
1 Answer
Yes
- Right click in the drawing area, and then click "Edit Sheet Format", to allow you to select the lines you want to adjust
- Open the Lines Toolbar - you can search for it if you don't have it visible
- Change the line weight using the relevant tool
See the .gif below to show this process.
