When looking at glazings within various public databases I see the fields "tir" shown often. E.g as seen below:
"glazing_data": {
        "tir_front": 0.0,
        "tir_back": null,
What does this field stand for?
  • $\begingroup$ Is it en.wikipedia.org/wiki/Total_internal_reflection? $\endgroup$ – Jebathon Nov 20 '20 at 16:52
  • $\begingroup$ That was my first thought but I dismissed it as it never applies to glazing because we never use it in that mode (looking through the edge of the glass). The air-glass-air refraction can't generate total internal refraction - unless the gasses are different on each side of the window. Post a link. $\endgroup$ – Transistor Nov 20 '20 at 20:06
  • $\begingroup$ Could you point us to the database you got this example from? $\endgroup$ – Wasabi Nov 21 '20 at 0:07
  • $\begingroup$ Have you considered: thermal infrared? $\endgroup$ – Fred Nov 21 '20 at 3:46
TIR: Thermal infrared (longwave) transmittance of the glazing layer.
Lawrence Berkeley National Laboratory has a windows program called THERM 6.3 / WINDOW 6.3 NFRC Simulation.
In pp 55 of this manual, there is a table referencing some properties of the glazing, including this.
pp 55
here is the Therm 6.3 prog dowmload.
  • $\begingroup$ Thank you. The data was from IGDB too $\endgroup$ – Jebathon Nov 23 '20 at 21:31
