differential drive vehicle in world frame
what would change in the kinematic model of the differential drive vehicle if i wanted to simulate it using pygame module in python ( pygame or opencv or any other one )
x_dot = (vl+vr)/2*cos(theta)
y_dot = (vl+vr)/2*sin(theta)
theta_dot = (vr-vl)/w
vr is the velocity of the right wheel
vl is the velocity of the left wheel
theta is the heading angle
it uses a screen coords system which start at the top left corner of the screen insted of the lower left my initial guess is since only the y axis is inverted then i should invert the sign of the y_dot
i hope i explained my question clearly the picture is in the link above
