If a spring-mass system is undergoing free vibration (oscillating up and down), then does it imply that there is no gravity?
My tutor always consider gravity when finding the Equation of Motion for such a system. But isn't gravity is an external force? If so, wouldn't the system be technically undergoing forced vibration as it is experiencing an external force in its direction of displacement?
  • $\begingroup$ So, on the Earth's surface or far enough out in space? $\endgroup$
    Commented Nov 11, 2020 at 5:42
3 Answers 3
11
It really depends on the problem and what you want to capture. Usually, in classes, it may be beneficial for the students at an initial stage to disregard gravity alltogether in order to simplify the equations of motion. Below are a few scenarios, starting from the most trivial.
Horizontal Case
In the following mass spring system:
https://minireference.com/_media/physics/mass_spring-highres.png?w=250
There is no point in regarding gravity (provided that there is no friction in the system).
Vertical Case
The following is the vertical case (from Khan academy ):
Even in this case, there is no point to consider gravity. Following is the explanation.
In this case, as you can see the undeformed spring, will have an undeformed length of L. That will be the point of equilibrium when no mass is applied.
However, when you add a mass m, there is a new point of equilibrium of the oscillations in translated by $L+d$. At that point, the following is true:
$$mg=kd$$
So the equilibrium point is now shifted by d downwards. Let's assume that the choose a coordinate system A that defines displacement 0 at this new equilibrium point.
In general, the net force on the mass at a position y (in the coordinate system A) is given by: $$\sum F_y(y) = Fs(y)-mg= k(d-y) - mg$$.
When the mass is at the equilibrium point then spring force and gravity are equal, and the net force is zero (see $mg=kd$ above) .
When you move the mass upwards at +y, then the spring force will be reduced, slightly. So the weight will overcome the spring force and the object will accelerate downwards. In that case the net force will be:
$$\sum F_y(y) = Fs(y)-mg= k(d-y) - mg = kd-ky - mg $$
After grouping terms together forces dependent on y and constant forces:
$$\sum F_y(y) = -ky +(kd- mg)= -ky$$
The same happens when you move y downwards.
So as you can see, even in this case the gravity PLUS a Hookean spring act just as one Hookean spring. That is why its safe to disregard gravity.
When Gravity CAN be a driving force.
There is (at least) one way that Gravity can be a driving force. That is the case of a pendulum.
Although this is not a typical mass spring system, it can be modelled as one after linearisation. i.e. the equations of motions of the pendulum without linearisation is:
$$\frac{d^2\theta}{dt^2} + \frac{g}{L}\sin\theta = 0$$
After linearisation (i.e. $\sin \theta\approx \theta$, as $\theta$ approaches 0):
$$\frac{d^2\theta}{dt^2} + \frac{g}{L}\theta = 0$$
This is very similar to the mass spring system. In this case, $\frac{k}{m}$ is substituted by $\frac{g}{L}$. This is also a harmonic oscillator, although its not a mass-spring system.
11
  • $\begingroup$ “What you need to understand from that point on is that both the spring and gravity are conservative forces, and they are both depended by the distance from the equilibrium point (lets call that y).” Gravity does not (at least in the equations you are using here) depend on the distance from the equilibrium point. $\endgroup$ Commented Nov 13, 2020 at 12:36
  • $\begingroup$ $\theta \to 0$ doesn’t really make sense outside of a limit. It should be $\theta \approx 0$. $\endgroup$ Commented Nov 13, 2020 at 12:37
  • $\begingroup$ You are right in both accounts. I consider the first comment more significant, what I had in mind was the gravitational potential, which is depended by the y level. Regarding the second (i.e. $\rightarrow$) I used the symbol to show that $\theta$ is approaching zero. In are relevant note, it would also be more preferable to put $\theta\approx \sin\theta$ $\endgroup$
    – NMech
    Commented Nov 13, 2020 at 13:20
  • $\begingroup$ You had gravitational potential in mind? That might explain the phrase “conservative forces”. I couldn’t understand what you meant in the context of this question. Regarding the second comment, it would actually be more preferable to put $\sin \theta \approx \theta$. $\endgroup$ Commented Nov 13, 2020 at 13:23
  • $\begingroup$ Hi @BrianDrake, I've made an update. If you have some time please have a look to see if I've missed something. $\endgroup$
    – NMech
    Commented Nov 15, 2020 at 5:47
Let's consider a mass and spring system in a frictionless open channel attached at one end to the channel. so that we can position the channel vertically or horizontally.
If we position the channel vertically it will initially deflect by the amount $Y_{initial}= \frac{mg}{k} $ due to gravity. But the gravity is not changing so it can not affect the vibration.
Then if we perturb the system it will vibrate. but the restoring force $\quad kd_x, \quad $, and the mass remain constant, unaffected by the gravity, hence the period and frequency will be the same for both the vertical and horizontal case.
The only difference is the initial deflection, Y at the vertical position, but the vibration and frequency will be the same with the horizontal case.
The period of vibration for the vertical case or horizontal case or in the space with no gravity will be:
$ T=2\pi \sqrt{\frac{m}{k}} $
  • $\begingroup$ This answer is very confusing. What are all these different symbols for position ($Y$, $d$, $x$ – well, actually, it was $d_x$)? It doesn’t clearly explain that you need to measure position relative to a new equilibrium point after introducing gravity. $\endgroup$ Commented Nov 15, 2020 at 8:45
This answer might look a bit silly, but I say that it is technically an answer to the question as written.
No, just the opposite. If you have some concept of “up and down”, then you must have gravity. How else would “up and down” be defined?
Oh, wait, you said “free vibration”. This is the key part of the question, and I will come back to it later.
I should hope so.
Yes.
Yes.
Now let’s talk about what you were really asking. You’ve probably seen such systems described with an equation like …
$$\frac{d^2 x}{dt^2} = -k^2 x$$
… even when the systems are vertical. So you’re thinking that this equation looks like the equation for free vibration, yet it should be forced vibration because of gravity, so what’s going on?
I said that it looks like the same equation. But it’s not really the same equation, because they have redefined $x$.
Because gravity is constant (independent of both position and time), you can very simply deal with it by:
  1. shifting the equilibrium point, which is effectively redefining $x$, and
  2. continuing to use the same equation.
With this overview in mind, you should be able to pick up the details from NMech’s answer.
