All searches resulted in ratio calculations, which makes sense, my question relates to creating a servo driven spindle with 1:1 ratio with timing belt. Is increased belt surface engagement important since its a toothed belt? Also system A and B are examples only.
    $\begingroup$ How much power? That drives the size of the belt and therefore its smallest pulley size. Check out belt manufacturers - plenty of info easily available. $\endgroup$ – Solar Mike Nov 3 '20 at 7:40
  • $\begingroup$ Whatever is the cheapest $\endgroup$ – jko Nov 3 '20 at 12:36
