When a frame structure is analyzed using a FEM computer software, does the program still generate mesh, even as a line mesh, on frame members, or we must do it ourselves?
This is really dependant on the package or the software used. Most commercial software packages such as ANSYS and COMSOL multiphysics have built-in mesh generators. If you are writing your own code to solve structural problems, then you could use open-source discretization packages like MeshLab or TetGen. Personally, I like using COMSOL multiphysics for these kinds of problems. Their interface is very intuitive for mesh generation.
  • $\begingroup$ Analyzing a frame structure with an auto-generated 3D solid mesh is overkill by several orders of magnitude, but if you have a million times more computing power than you actually need to get the work done, wasting it doesn't really cost much - except when it produces meaningless stress concentrations near the joints which make it hard to interpret the output! $\endgroup$ – alephzero Oct 23 '20 at 20:32
  • $\begingroup$ Yes that was what I was thinking, so in other words, we do not do auto meshing in frame structures, and we just draw/show the frame line or shell elements and the program divides each member evenly to several pieces and that is all we need for frame or truss structures correct? I mean that is the mesh here, but it is not like a 3D mesh which is overkill right? So this 2d or 3d auto meshing would be more beneficial for the people who analyze irregular 2d or 3d problems correct? $\endgroup$ – user3600630 Oct 24 '20 at 19:05
