First off, this is not a homework question or anything like that. I'm trying to build a catapult to launch a payload using a flywheel as an energy device!
It goes like this:
  1. The flywheel spins up to maximum speed. All other components are at rest.
  2. The catapult lever (in resting position, with a payload at the end of it) engages a tooth.
  3. The flywheel tooth (always extended) connects with the catapult lever tooth and rotates it over a certain angle. During this time the flywheel is slowed down a certain amount and the lever gains a great amount of speed.
  4. At the end of the interaction between the flywheel and the lever tooth (after some degree of rotation) the lever gets to the end of its stroke and abruptly stops, the payload continues flying upward and the remaining energy of the flywheel makes it continue to spin (it can freely "slip" past the lever tooth at the end of the movement).
I've attached a couple pictures which describe the two states, T0 and T1 (basically step 3 and 4 respectively).
state T0
state T1
My question is, how do I determine the final energy of the flywheel after this interaction given the following parameters: Moment of Inertia and initial Kinetic Energy of the flywheel, mass of payload, and the basic geometry between them. Assume the weight and inertia of the catapult lever are negligible and there is no friction between the interaction of the two moving parts.
I originally thought this problem would be as easy as assuming all the kinetic energy of the flywheel just went into the upward motion of the mass (the flywheel would come to a complete stop). However, after thinking about it for a while I realized it is probably not that simple at all...I smell some differential equations which scare me and has been a while since I've done any of that which is why I am asking for some help. Maybe it's not that complicated after all, but I am at a dead end. Anything would be appreciated.
Thanks in advance.
  • $\begingroup$ As an upper limit - maximum power transfer theorum says max power is transferred when energy in flywheel and mass are equal. Mass energy becomes 0.5 x m x v^2 and max height is given by E=mgh so H_max = E_flywheel/(2 x g x h) $\endgroup$ Oct 22, 2020 at 2:01
  • $\begingroup$ Thanks @Russel McMahon for taking the time to look into this question. So, if I understand you correctly, should I expect the energy of the flywheel to essentially be divided in half after the launch (regardless of initial conditions)? $\endgroup$ Oct 22, 2020 at 2:06
  • $\begingroup$ MAXIMUM energy transferable is 50%. Getting less or much less is easy :-).You may/will have to design or trial and error experiment to achieve this. Lever ratio, cam dwell time, will affect it. $\endgroup$ Oct 22, 2020 at 2:12
  • $\begingroup$ Not perfectly relevant, but interesting nonetheless youtu.be/RVT5i4nhIGs $\endgroup$ Oct 22, 2020 at 8:15
This is a very interesting problem.
Energy approach
At first I was inclined to solve it though energy i.e.:
$$\frac{1}{2}I_{fly}\omega_0^2 = \frac{1}{2}I_{fly}\omega_1^2 + \frac{1}{2}I_{lev}\omega_1^2 + \frac{1}{2} m \cdot (\omega_1\cdot L)^2$$
where:
  • $I_{fly}$ is the moment of inertia of the flywheel $I_{fly} = \frac{1}{2} m_{fly} r_{fly}^2$
  • $I_{lev}$ is the moment of inertia of the lever $I_{lev} = \frac{1}{12} m_{lev} \left(L+ \frac{D_{fly}}{2}\right)^2 + m_{lev}\left(\frac{L-D}{2}\right)^2$
  • $\omega_0$, $\omega_1$: are the angular velocities at the beginning and end of engagement respectively.
  • $m_{lev}$: mass of the lever
  • $m$: mass of the "missile"
From this equation, it is pretty straight forward to obtain the $\omega_1$:
$$\omega_1 = \sqrt{\frac{I_{fly}}{I_{fly}+ I_{lev}+ m \cdot L^2}}\omega_0$$
Then the only thing you need to do is work out the launch angle ($\theta$), break up into components and you can estimate maximum height and horizontal distance traveled.
Although, I believe the above mentioned method will give you a ball-park figure, I doubt it will be accurate. There are two assumptions 'with issues' here:
  • there is full engagement during the duration of the slow down of the flywheel (i.e. there is no impact).
  • disengagement between the mass and the level occurs the moment the engagement of the tooth with the lever finishes. However, the time of disengagement of the mass will be depended on factors such as how its mounted on the level, coefficient of friction etc.
Impact
The main problem with the above approach would be the speed of impact during first engagement.
If the lever and mass are small then the angular velocity of the level + mass will be greater than the angular velocity of the flywheel, i.e. there will be only brief contact at the beginning of the impact and maybe secondary impacts (which might not provide any extra energy to the mass.)
If the lever and mass are large then probably what will happen is that the flywheel will either recoil or slow completely down. In any case, this means that the travel angle will not be $\theta$ but something else entirely.
  • $\begingroup$ Darn, this means my idea is not going to work because the inertia of the payload is going to be much larger than the inertia of the flywheel so it would just "recoil". Thank you for the insight. $\endgroup$ Oct 27, 2020 at 2:32
  • $\begingroup$ if you have much higher moment of inertia you might be able to launch the projectile quite high. The problem is that I doubt you will be able to point it. $\endgroup$
    – NMech
    Oct 27, 2020 at 6:46
  • $\begingroup$ In order to properly analyse what would happen you'd need to look into eccentric impact of rigid bodies. The main problem with the analysis is determining the coefficient of restitution. Because this is an interesting problem -but unusual and it requires a few calculations- , when I get some time I'll probably update the answer. $\endgroup$
    – NMech
    Oct 27, 2020 at 10:45
As an upper limit - the maximum power transfer theorum says maximum power is transferred when energy in the flywheel and the mass are shared equally.
Height_max = E_flywheel/(2 x m x g)
In reality actual energy transferred and consequent height will approach but not equal this.
eg 100 gram mass, 100 Joule flywheel energy
Height <= E_flywheel/(2 x m x g)
= 100 /(2 x 9.8) m
~= 5 metres
Drag coefficient of the projectile will alter actual height.
At "launch" E_flywheel/2 = 0.5 x m x V^2
so V = (Ef / m)^0.5
In the above example
V = sqrt(100/.1) ~= 32 m/s
That's fast enough for drag to make a significant difference depending on frontal area and profile.
  • $\begingroup$ If I am understanding correctly, does this mean that the moment of inertia of the flywheel should be as close to the moment of inertia of the lever with the payload (point mass moment of inertia)? $\endgroup$ Oct 22, 2020 at 2:39
  • $\begingroup$ @thisissparzo sort of but that's usually backwards -> here you'd usually have a flywheel that you wish to match to a projectile. For a given projectile you can then match the transferred energy by changing lever length and length ratios, cam shape and dwell time and .... . A more enrgetic flywheel can always impart more energy than a lower energy one - matching how it is coupled is 'the trick'. $\endgroup$ Oct 22, 2020 at 7:01
