-1
With conventions that I adopted shown below
I drew roughly the shear force and bending moment diagram of a simply supported beam with concentrated load at the middle. Now while drawing I drew both shear force and bending moment diagram starting from the same end.
1)First from left end enter image description here
2)Then from the right end
But here how i found out the bending moment was by algebraically adding the areas under the shear force diagram starting from the one end and plotting them along the length of the beam towards the other end. Thus when finding the area under shear force diagram I took area under negative shear force as negative (i.e. negative bending moment).
Is this wrong? Because I am getting positive sign for bending moment when i start drawing from left end and negative sign for bending moment when I start from the right end. Although the shear force diagram is same from both ends.
I have noticed that I didn't use the sign convention I mentioned in the first place while drawing the bending moment. But I have seen in one of the lecture video that you can add up the shear force diagram areas algebraically and get the bending moment diagram easily .[link of the lecture]
  • $\begingroup$ Hi, what does ve stand for? $\endgroup$
    – NMech
    Oct 9 '20 at 8:55
First of all the bending moment, according to the usual convention (and the one you are presenting here) is positive.
However, the problem originates when you add the area of the shear force. (Probably without realising it), what you are doing is you integrate the shear force over dx $\int_0^L V(x)dx$.
I am using the mathematical notation because it is easier to see what's happening.
What happens when you start from the other end (L) is the following: $$\int_L^0 V(x)dx$$
However, when you reverse the integration limits you get:
$$\int_0^L V(x)dx = - \int_L^0 V(x)dx$$
So when you are starting from right end, essentially what you are doing is that you get a reverse sign. I.e. a positive shear force, creates a negative bending moment, and vice versa.
In order to make that more easily digestible (for engineering students that are allergic to calculus), the following convention is often used:
  • $\begingroup$ There is no 'usual convention' for bending moment sign. The convention I was taught at undergraduate level is to plot it so the diagram line is to the side that's in tension - so for this case, the bending moment is -ve, i.e. the opositte of what is here claimed to be the 'usual convention'. You can't even say 'sagging is +ve' because when it's (say) a column, which direction is hogging and which sagging? Pick a convention to use for each analysis and apply it consistently in that analysis. $\endgroup$
    – achrn
    Oct 11 '20 at 13:03
