-1
I don't fully understand the section b. How does the math in fhat voltage division equation work out to be 200 ang(-113.13) volts?
The voltage division equation is $$V=\frac{-j40}{90+j160-j40}(750\angle30)$$
You can combine $j160-j40$ in the denominator to give $j120$ and convert $750\angle30$ from polar to complex rectangular $(x,\ jy)$ form by: $$(750\cos(30),\ j750\sin(30))$$. Now we have:
$$V=\frac{-j40\times(649.5+j375)}{90+j120}$$ $$=\frac{-j25980+15000}{90+j120}$$
Convert back to phasor notation $A\angle B: A=\sqrt{x^2+y^2},\ \ B=\tan^{-1} (\frac{y}{x})$ which gives:
$$V = \frac{30000\angle -60}{150\angle 53.13}$$
In phasor notation this simplifies to:
$$V=30000/150 \angle (-60-53.13) = 200\angle-113.13$$
This equation is using complex arithmetic, where each value has both a real and an imaginary component. Complex numbers can be expressed either in rectangular form $R + jI$ or in polar form $M\angle\theta$. There are many online resources that will help you learn to use complex arithmetic.
