I was watching a YouTube video to understand the concepts of hoop/circumferential stress and axial/longitudinal stress in thin-walled cylinders and their formula derivation.
So the formula of the Hoop Stress: $$\sigma_{hoop}=\frac{(p * r )}{t}$$
where $p$ is the internal pressure of the cylinder, $r$ is the internal radius of the cylinder, and $t$ is the thickness of the cylinder,
The formula of Axial Stress: $$\sigma_{axial}=\frac{(p*r)}{2t}$$
My question is: They have mentioned in the video that since the axial stress is less than the hoop stress, then the thin walled cylinder is more likely to experience failure along its axis than along its circumference.
I still don't agree that just because the stress along its axis is smaller than that along its hoop, then it is more likely to undergo failure along its axis.
The stress is meant to resist deformation, and to resist the applied force. The axial stress is smaller just because the internal pressure applied along the axis is smaller than the pressure applied along the hoop.
So yes the axial stress is smaller than the hoop stress, but on the other hand the applied internal pressure is less along the axis than it is along the hoop of the cylinder.
