(please note that this is a duplicate of a question the electrical forum, however, there are some mechanical subjects that would be better suited here.)
I am trying to make an electric go-kart. I am new to the forum, so I may be missing some information but any help is greatly appreciated. After doing some math and discussing with friends I found the following with the given information. I have 4, 24V 14A motors, all connected to a read drive axle. I have 2 pairs of motors on each side of the drive axle. The motors have an 11 tooth sprocket that is chained to a 68 tooth sprocket that is connected to the drive axle. I currently have 2, 12V 7Amp 20 hour lead-acid batteries, which provide my 24V. Each pair of motors is connected in parallel to ensure they both get the 24V. However, the motors do not spin, even when there is no load (The wheels aren't contacting the ground). I believe that this may be because the motors do not have enough amps, only receiving 7 Amps of the 14 Amps from the batteries, because there are 2 motors in each pair. My main goal is to get the kart moving. I weigh about 130lbs, and the kart is likely around 30lbs. Would getting a battery/batteries with move amps (28A) allow the motors to run properly? Any advice is really appreciated.
All the information I know
Each motor is a DC motor that needs 14A and 24V The motor has a sprocket of 11 teeth The Watts of each motor is 250 The motors are rated to have an RPM of 2750 or around 45.83Hz
The drive axle has a sprocket of 68 teeth. The 68 toothe sprocket is 5.5" The wheel diameter is 10"
If my math is correct, given the ratio of the motors to drive shaft. Each motor produces 5.45Nm of torque, and after the sprockets, the torque is 33.69Nm. I don't know what impact the 4 motors would have on the torque, nor do I know what the torque is for each side. I really just want this kart to move.
Would removing motors allow my vehicle to move? I think that my power supply does not provide enough amperage to my motors. Would having 1 or 2 motors be better in this situation?
