I'm a total novice and self taught, currently designing and building a workbench for woodworking with an adjustable height top. This is the last major part to finish and I'm having trouble determining which bearing configuration to use.
EDIT: I essentially am trying to do this, except with the drive mounted below the floor instead of over it: https://www.youtube.com/watch?v=URrEdGeoDBs enter image description here
Overview: There are four legs (4x4s) that travel in a cuff. I'm designing for the top to carry and lift about 400lbs, but more likely will be under 100lbs (with each leg being able to lift 100 lbs max / 25 lbs). Total amount of lift is going to be between 15-17" depending on the bearing configuration. After the bench is lifted to different heights, I'll have spacers to hold it in place and then back off the force of the lift (so if I'm hammering something, I won't be hammering against the threaded rods)
The rising mechanism is driven by four threaded rods (3/4"). Below the table, each rod will have a gear, and all four will be connected by one roller chain driven by one drive gear (which I'll use an electric drill to turn). On the threaded rod is a square nut, that fits inside a square tube held in place by two tension pins (so as the rod turns, it will push up against the tension rods/square tube which pushes the top of the workbench up and down).
Some sketches:
Problem Description and Research:
  • Because the gears must be located under the bench (the inside of the bench is used for some tools and whatnot), I need a way to brace the forces of the rod/workbench top against the bench floor.
  • From what I understand, radial bearings are designed to handle perpendicular forces to the shaft, while thrust bearings are designed for mostly axial/thrust forces parallel to the shaft. Also, the more hardware I have above the workbench top, the less rise I can get, so being really economical with what I use above the workbench is important.
I bought a bunch of different radial and thrust bearings to try out an assortment of options, they all have pros and drawbacks. (For underneath I'm using a flanged bearing along with the gear and collar clamp to hold it in place, I'm struggling with the above floor bearings unless you have other ideas on the underneath part)
Option 1): Flanged / pillow radial bearing. https://www.amazon.com/gp/product/B01NCUJH8I/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 These bearing are rated for Static (axial) Load Rating: 6.65 kN/1500 lbs and Dynamic (radial) Load Rating: 12.8 kN/2900 lbs. On the pro side, the flange plus set screws will allow me to hold the threaded rod in place, along with a collar it should hold well and not slip. Con, I don't think this is the right kind of bearing. I tapped one with a hammer and it started to come out of the race a little...but maybe for these types of lifting forces it'll be fine?
Prototype picture: http://prntscr.com/uf1sa9 (2x4 represents the workbench floor, flange bearing above with collar above.) enter image description here
Option 2): Thrust Bearings. https://www.amazon.com/gp/product/B01EBKYSWA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 If I use thrust bearings, which seem to be the correct type of bearing to use, they bind and rub on the floor of the bench because the inner race is proud. I've tried drilling a wider hole, but the tolerances are too tight to solve the problem. I feel like there's a configuration that this could work but I've spent days playing with different types and haven't found a solution.
Quick prototype pics:
Option 3: I also have a bunch of these radial bearings...but pretty sure they're not the right type for this application? http://prntscr.com/uf22dd enter image description here
So, should I go with Option 1, 2, 3, or is there another / easier configuration that would make a lot more sense? If you know of a better bearing design a link would be really useful as a visual as well.
Thank you!
Unless you're spinning the rods more than 100 rpm bushings should work, are cheaper and easier to work with than bearings.
Examples
Comment added to answer: the video makes it much more clear what you're trying to accomplish, thanks. Option 1 should work for you. The bearing in that housing is designed for radial loads, but typically a deep groove radial ball bearing can handle an axial load equal to 50% of it's rated radial load. Or just steel washers sandwiching bushings, but it seems you already have all the pillow block bearings.
9
  • $\begingroup$ How would the rods stay above the bench if I used bushings - just that clamping collar that would grind against the bushing? Wouldn't that add a lot of extra force to turning everything? (I'll use an electric drill to turn the "drive") $\endgroup$
    – Gisto
    Sep 10, 2020 at 17:43
  • $\begingroup$ (The drill can spin up to 1600rpm. The drive gear has 10 teeth, each gear of the threaded rod has 24 teeth) $\endgroup$
    – Gisto
    Sep 10, 2020 at 17:49
  • $\begingroup$ There would be some friction from the locking collar rubbing on the bushing flange, yes, but they are designed to do that. Additional recommendation is to have your threaded rod be the fixed member and rotate the nut with your drive chain. That is a lot less inertia and how ballscrew devices operate. I'm also wary of coordinating the timing of 4 different chain drives, if one of them is tensioned unequally your whole table would bind up. $\endgroup$
    – jko
    Sep 10, 2020 at 19:04
  • $\begingroup$ @bushing flange - gotcha. I'm surprised the friction would not be insignificant with that much weight on it. I guess they'd have to be replaced periodically? Hmm....if the nut is the thing raising the table, how would I rotate all four together from underneath if the nut is above? Have a sketch or video handy by chance? Oh, there'd be one drive train that connects all four corners together - apologies if that wasn't clear from my chicken scratch haha Thank you! $\endgroup$
    – Gisto
    Sep 10, 2020 at 20:26
  • $\begingroup$ I added a youtube video of an example with screenshot as well $\endgroup$
    – Gisto
    Sep 10, 2020 at 21:06
