I am wondering how a helicopter manages to stay balanced and stay in one spot while it is in the air.
I understand that there is a second rotor that is used to counteract the angular momentum and also the use of swashplate to direct the helicopter forwards and backwards.
Assuming the angular momentum of the main rotor is not an issue, Is there a sensor on the helicopter that can detect if it is not upright? Is the swashplate then adjusted to tilt the copter into an upright position?
