-1
enter image description hereBetween Glue Laminated and steel plate sandwiched between two wood beams, which one is more dimension-ally stable?
  • $\begingroup$ Do you mean which assembly is more stable? Please provide two sketches with load schedules, and tell us what is changing - temps, humidity, loads? $\endgroup$
    – Phil Sweet
    Aug 27 '20 at 22:09
  • $\begingroup$ Glue laminated can be fabricated in longer lengths I believe $\endgroup$ Aug 28 '20 at 6:04
-1
I'm trying to understand what it means by dimensional stability. Both beams highlighted are engineered. So without having more detail information, which one is more stable dimension-ally? enter image description here
    $\begingroup$ The way Stackexchange works, you ask a question, and then if you want to add to it, you edit your question. It is not a traditional forum. If you answer your question then that belongs here -- but this looks like an addendum to your question, which you should add to your question by editing it. $\endgroup$
    – TimWescott
    Aug 27 '20 at 23:50
