I need help to check a calculation I did. I want to know if it is possible to use this method or if I am using an assumption which is wrong. Let me explain the problem, a beam with length $l$ is fastened in one end. A force $F$ an a moment $M_v$ is applied at the end of the beam, see figure below. The beam has a circular cross-section. Due to the force, the end of the beam will deform a length $\delta$. Only the deflection is known and the geometric parameters, such as the length and diameter.
Using Euler-Bernoulli beam theory the deflection can be expressed as:
$$\delta = \frac{Fl^3}{6EI} \tag{1}$$
Where $E$ is the Young's Modulus of the material and $I$ the inertia, which is $I=\frac{\pi d^4}{64}$ for a circular scross section. Here $d$ is the diameter of the beam.
Inserting the inertia in (1) and rearranging it as an expression of $F$ gives:
$$F = \frac{3 \delta \pi d^4 E}{32l^3} \tag{2}$$
This can be inserted in the general formula for maximum bending stress in a cross-section
$$\sigma_{max}= \frac{Fl}{\frac{\pi d^3}{32}} = \frac{32Fl}{\pi d^3} \tag{3}$$
Here the bending resistance for a circular-cross section has allready been inserted in the formula and the bending moment has been replaced for the maximum moment which is $Fl$.
This is the part which I am not so sure on, I use the force from (2) and insert it in (3) to get the maximum stress. Please let me know if this is possible or if I am making an error.
Furthermore, the shear stress can be calculated from $\tau = \dfrac{M_v}{W_v}$ where $W_v = \dfrac{\pi d^3}{16}$, which is the torsion resistance in the material. I then proceed to use the von Mises yield criterion to get an estimate of the maximum stress in the material.
$$\sigma_{von\ Mises} = \sqrt{\sigma^2+3\tau^2}$$
As I asked before, I am mainly interested if this is a possible way to proceed with solving this problem or if I am using some methods/assumptions which are wrong.
Beam loading case
In general what you are doing is ok. Assuming you have small enough deflections (either through bending or torsional), you can independently solve the problems. I.e.:
  • Calculate the Force required to obtain the bending exactly as you have done. $$F = \frac{3 \delta \pi d^4 E}{32l^3}$$
  • Calculate the magnitude of the shear stress.
Caveats
However, from that point on there are a few caveats. Regarding:
a) bending: the maximum magnitude of normal stress you are calculating is at the top and bottom of the beam. Any point on the neutral axis should have a magnitude of zero.
b) torsional shear: The magnitude at the distance $\frac d 2$ is constant but the direction changes. see the following image:
Torsional stress at differet point of the crosssection1.
the magnitute of the maximum torsional stress is correctly:
$$\tau_t = \frac{M_u}{\frac{\pi d^3}{16}}$$
c) Shear: Although usually discarded there is also a shear stress associated with $$\tau_s = \frac{F}{\frac{\pi d^2}{4}}$$. Normally, that is very small, but also it has a constant direction (downwards in this occasion).
The point you need to take is that you need to add as vectors $\tau_s$ and $\tau_t$. Therefore, at different point in the material you'd have different values. Given image 1 and taking points A,B,C,D anti-clockwise, the resultant shear stress will be:
  • at the rightmost point ( Point A (+x, y=0) will be $$\tau_{A, res} = \tau_s - \tau_t$$.
  • at the topmost point ( Point B (x=0, +y) will be $$\tau_{B, res} = \sqrt{\tau_s^2 + \tau_t^2}$$.
  • at the leftmost point ( Point C (-x, y=0) will be $$\tau_{C, res} = \tau_s + \tau_t$$.
  • at the bottommost point ( Point D (x=0, +y) will be $$\tau_{D, res} = \sqrt{\tau_s^2 + \tau_t^2}$$.
Maximum stress
So the main thing is regarding your equation of the Von Mises. Which values do you plug for $\sigma$ and $\tau$.
You'd need to go through each point and apply the corresponding stress:
  • Point A, use $\sigma_{A} = 0$ and $\tau_{A, res} = \tau_s - \tau_t$
  • Point B (and D), use $\sigma_{B} = \frac{32Fl}{\pi d^3}$ and $\tau_{, res} =\sqrt{\tau_s^2 + \tau_t^2}$
  • Point C, use $\sigma_{A} = 0$ and $\tau_{A, res} = \tau_s + \tau_t$
Unfortunately, these are not the only points you need to check. For example, you should check at least at $\pm 135$ degrees (in that quadrature in the image $\tau_s $ and $\tau_t$ do not cancel each other). But that is the idea.
