10
During CES2015 a well know Graphic Processor Unit (GPU) manufacturer introduced a new GPU. These GPUs need complex thermal management to keep the processor cool. Most GPU accelerator card manufacturers develop new graphics accelerator cards that use primitive thermal management technology compared to today's advanced technologies. Most of us know this technology as fans that manage this unwanted thermal energy, as seen in this image of a graphics accelerator card:
Inno3D-iChill-GeForce-GTX-980-HerculeZ-x4_1
What barriers do engineers need to overcome to convert this wasteful thermal energy to useful electrical energy?
Below is a temperature profile of a GPU card.
GPU Temperature Profile
References:
9
    $\begingroup$ Heat generation of those is rather variable, easier would be to use liquid cooling and use the radiator as a footwarmer. $\endgroup$ Jan 30, 2015 at 11:57
    $\begingroup$ First, measure the temperature of the card, and calculate the Carnot efficiency limit. $\endgroup$
    – 410 gone
    Jan 30, 2015 at 12:48
  • $\begingroup$ @EnergyNumbers, I am not a ME. Thus I don't have much experience of knowledge thermodynamics. But I see lot of energy that can be harvested and fed back into the system $\endgroup$ Jan 30, 2015 at 12:51
  • 3
    $\begingroup$ This approach seems flawed. You want to take energy wasted as heat in one process and convert it back into useful energy. A better approach is to make the first process more efficient so as not to generate so much heat. $\endgroup$ Jan 30, 2015 at 12:52
    $\begingroup$ @MahendraGunawardena I understand that you wonder why this cannot be done. I'm trying to help you understand. So measure the temperature of the card. And then calculate the Carnot efficiency limit. And then add that information into your question. $\endgroup$
    – 410 gone
    Jan 30, 2015 at 13:22
3 Answers 3
15
There is heat that can be recaptured, but you won't get much of it away. As one of the commenters has mentioned, your absolute maximum is the Carnot efficiency.
$$\eta_{Carnot}=1-\frac{T_c}{T_h}$$
This is an idealized condition, you'll never reach this efficiency. But to find our limit, let's figure it out anyway. $T_c$ will just be room temperature, it might be slightly warmer inside the tower, but we'll give ourselves the benefit of the doubt and pick a nice round number at 20C (293K). $T_h$ will vary as the GPU works harder (this is one of the issues with this design in general; the power you get from the cooling system won't be consistent because GPU temperature varies depending on how much you're stressing the chip.) We don't want to run it too hot and damage the card, that defeats the purpose of a cooling system.
After some quick searching (Google "GPU operating temperatures," you'll see a bunch of forum posts that give a lot of different numbers, none of which I think are strong enough to cite, but I'm pooling their data to make my own assumption) it looks like most cards have a strong upper limit of ~100C before you start to do serious damage. However, running that hot will still reduce the life of your card, and judging by the picture in the question, this is a nice card for which we've paid a pretty penny, and we want to keep it around as long as we can. 70C is a good place to shoot for, but 80C (353K) is still probably pretty safe, and we want our best possible case. With those numbers, we get
$$\eta_{Carnot}=1-\frac{293K}{353K}=0.17$$
This means that, at the very maximum, the best we can do is to get 17% of the heat we're generating on the card back as electricity to power something in the tower. We can vary the card temperature, and as it goes between 60C and 100C, efficiency goes between 12% and 21%. Regardless, we're not getting a lot back.
That's the max efficiency though. This site, which sells thermoelectric generators, says that the top of the line TEGs will run at 8% efficiency. While this is better than the nothing that we'd have been getting before, the real issue here is cost and implementation. TEGs are not cheap, and cooling fans are. A basic cooling system is also much easier to install. Even if we can hook up a TEG to cool the card, we have to find something we can do with that electricity, and we don't want the variable power to be used for an critical components. Tower lights and extra fans are probably the extent of our usage.
So to answer your actual question in there, I'm sure we can find all kinds of creative ways to get that heat converted into electrical or mechanical work. Making it "useful" is an entirely different story.
    $\begingroup$ Fun case study, courtesy of Professor Klaus Lackner: picture a PC in the International Space Station, powered by a battery supplemented with a Carnot heat engine attached to the PC's heat sinks, where the cold reservoir is space. And then calculate the net power supply required ... $\endgroup$
    – 410 gone
    Jan 30, 2015 at 15:34
    $\begingroup$ Nice answer (+1), the other problem is that by putting a TEC in the heat path you will make the thermal conductivity higher, meaning the primary job of cooling is harder. Sort of similar to sticking a wind mill on top of your car to generate electricity from the car movement. $\endgroup$ Jan 30, 2015 at 15:42
  • $\begingroup$ @Trevor Archibald: Thank you for the technical explanation. What I am reading is Energy harvesting is possible, but based on the current economics it is not practical from a monitor standpoint. Similar to the solar panels, and Toyota prius. Give a tax incentive sales of solar panels and Toyota prius goes up. From an electrical engineering standpoint, if 17% energy can be harvested, this energy can be stored in an energy reservoir such as a supper capacitor and then reused back in the system in stages using some type of power switch mechanism. $\endgroup$ Jan 31, 2015 at 0:56
13
Trevor Archibald has given you a really good answer, but I see from your comments a diffferent answer might be useful, as you still think this could be viable with the right economics.
It wouldn't be. The issue is engineering, not economics. It's a bad idea from the economic perspective, certainly; but changing prices won't make it a good idea. It would still be a bad idea. Let me explain.
low-grade heat
Low-grade heat is heat that is a few Kelvin or tens of Kelvin above room temperature.
getting rid of the heat quickly is the name of the game
George Herold points you in a comment to one reason why energy harvesting on the card would be a bad idea: the thermal conductivity of the card is designed to be high.
Getting rid of heat quickly is particularly important in IT equipment, where the electrical efficiency of the equipment is really really staggeringly poor. And that means that of the electricity you put in, almost all of it is going to get turned straight into heat. There is a theoretical minimum amount of energy needed to flip a bit, regardless of the medium on which the bit is stored. All the rest of the energy put in above that minimum, is going to turn into heat straight away. In order to protect the equipment, you need to get rid of that heat as fast as possible.
So the card is designed to get rid of heat as fast as possible. Anything you put in the way, such as your proposed energy harvesting device, will slow the rate at which heat leaves the card. That will raise the card's equilibrium temperature. And that will radically shorten the life of the card. That will happen regardless of the price of electricity.
it's not about the price of electricity
And this idea that if the price of electricity were high enough, it would make harvesting low-grade heat worthwhile, is simply wrong. If electricity is that valuable, then it's worth making the card more efficient in the first place, so that there was less waste heat: first, reduce the consumption of high-value energy, before trying to recycle low-value energy. And that brings me to ...
energy versus exergy
Heat is, in a large proportion of cases, a waste product. It's almost always the least useful form of energy. That's really what the Carnot efficiency limit is telling you: that to get any work out of low grade heat, you can only do so with very low efficiency; that is, almost all of the heat will stay as heat.
When doing engineering with heat and other forms of energy, it's very useful to build up an intuition to distinguish between energy (the thing measured in joules) and exergy (the thing that gets work done). The form that energy is in, determines how much work it can do. Electricity can do huge amounts of work efficiently - it has very high exergy. Low-grade heat can do very little work - it has very low exergy.
Once you've created low-grade heat, you're already at the end of the line for exergy (useful energy). Almost all uses of energy end up at low-grade heat. It's the final form for pretty much every chain of energy conversions. And, at the cosmic scale, it is (as far as we can tell) the final form for every single joule, in the heat death of the universe.
Low-grade heat is the end of the road. If you want more work out of those joules, then get that work done before those joules are in the form of low-grade heat.
  • $\begingroup$ Absolutely. Low-grade heat has pretty much one use, and that's heating something, so long the something you want to heat is exactly where the low-grade heat already is, or can be reached with a very simple fan and short duct. $\endgroup$ Jan 31, 2015 at 3:22
Not an answer per se. But worth a revisit.
The new generation of GPU cards can run at very high temperatures, though whilst gaming the temps vary, another area that displays constant temperatures is whilst crypto mining, where cards can run between 80c to 90c, since the load on the card is always 100% the temperatures stay consistent, depending on the clock settings set by the user.
With the previous answer, of an upper limit being 21% an educated guess would be around a consistent 30%
My interest would be using a TEG instead of any type of fan cooling. Which will inevitebly take core temps higher, however, because GDDR6 dissipates heat through the bottom of the card rather than the top where the fans are mounted, during mining, they are all but useless.
