-1
First off non-engineer apologies,
A plate of 5251 Aluminium is used to support the load of a centrally seated human I estimate a load of 1 kilonewton.
The beam measures a length of 1000mm, 100mm wide.
For a thickness 6mm I calculate the Moment of Inertia to be 1800mm4 and given a Elastic modulus of 70000MPa the maximum deflection to be about 14cm.
Assuming the beam will fail under tension of 130-240 N/mm2 will it break or permanently deform ?
How thick would the plate have to be before the process would be elastic ?
(6mm is the thickest plate though I could stack them; I can get 5mm being much cheaper)
  • $\begingroup$ I have reveiwed engineering.stackexchange.com/questions/5808/… but I am no clearer $\endgroup$
    – ArchNemSyS
    Commented Aug 12, 2020 at 14:59
  • $\begingroup$ A single flat plate, or a stack of plates, is a very inefficient way to support the load. For example a T-section beam would be much lighter and stiffer. $\endgroup$
    – alephzero
    Commented Aug 12, 2020 at 22:56
Using the properties you mentioned, the equation for bending stress is
$$ \sigma = \frac{M}{I_{xx}}\cdot y_{max}$$
where :
  • $M=F\frac{l}{2}=0.5kNm$ (that's a lot)
  • $I_{xx} $= 1800mm4
  • $y_{max} = \frac{thickness}{2}=3[mm]$
The results is a whopping 833.[MPa], so it will fail.
Assuming you use a solid beam (same material), you can estimate the minimum thickness from the following equation:
$$ h_{min}= \sqrt{\frac{6 M}{b\cdot \sigma_{max}}}$$
The only thing new thing here is that $\sigma$ is substituted for $\sigma_{max}$. Al does not have a clear yield area like steel has. Therefore "elastic region" is a bit vague (normally you'd settle for proof stress). However, given the ultimate tensile properties you posted and the intended use, I'd settle for at least 100[MPa], which yields a minimum thickness of 17.5[mm].
OK, now for the tricky part. If you plan to stack them, then you'd need a lot more. A rough estimation is between 8 or 9 plates of 6[mm]. For why that happens you might want to read the following question
