ESC hydraulic circuit
Source: https://www.kfz-tech.de/Engl/Buchprojekte/HBremse/ESP3.htm
Firstly, I don't know if this is the right StackExchange, but I will try nevertheless.
Above I posted a picture of the hydraulic circuit of an ESC (Electronic stability control) system (with ABS (anti-lock braking system). Now the upper 4 valves (2 per circuit) are used to autonomously build up pressure (ESC intervention or autonomous emergency brake). Normally the inner valve is open, which leads thought the ABS valves directly into the wheel.
When ESC wants to brake on its own, it closes the inner valve and opens the outer valve ("suction valve"). This way, the path leads through the hydraulic pump and backflow is blocked by additional directional valves (I guess this is how the autohold function is working). By operating the pump, the system can now build up pressure. But since this option is only available circuit-wise, it would put pressure on two wheel at a time. As commonly known, ESC stabilizes a vehicle by braking a single wheel to induce a rotating force countering the instability.
The only possibility I see braking just one wheel is by blocking it with the ABS valve. Does that mean that, even when the driver steps onto the brake pedal, the wheel which is not intended to be braked is completely not brakeable? I dont think this would lead to a good dynamic, since it would have much less pressure than the whhels in the other circuit which are unaffected. Or does the ESC react to this and works like an electronic brake force distribution by temporarily letting fluid flow into the unbraked wheel, so that the pressure in this wheel is regulated to be the same as in the other circuit?
The computer will control the valves to provide a braking force at the wheels where it is needed and won't brake wheels that don't need braking, it won't help to equalize the braking force to all wheels when only one needs to be specifically braked.
There are several sources about how this type of hydraulic control work, Mannesman Rexroth Sigma do a set of 6 (that I have) but they may only be made available to staff - I have not seen them on sale publically but they are specialist publications so may not be found easily, and I am sure that they will not be cheap. However, they do some excellent explanations of the 2nd order control systems.
  • $\begingroup$ I understand this, it is also what i assumed from the beginning. But when it wants to brake a single wheel, it does not have the possibility to do that, because the pump will brake both wheels in the circuit. The only possibility is to block it with the ABS valve, but then it would be completely without pressure when the driver also brakes. I dont' think that would happen, since then you would also get forces on the other axis. $\endgroup$ Aug 2, 2020 at 10:33
  • $\begingroup$ If you understand that, then please show how the left and right sides are connected together. $\endgroup$
    Aug 2, 2020 at 10:37
  • $\begingroup$ (With understanding, I mean that it only brakes what it wants to brake). They are not connected, but you have two wheels on the left side. And the pump will brake both of them, even if you only want to brake one. So how do you configure the valves to brake only one wheel, without completely blocking access to the other wheel. $\endgroup$ Aug 2, 2020 at 10:48
  • $\begingroup$ Each caliper has a controlling valve that is independant. $\endgroup$
    Aug 2, 2020 at 10:50
  • $\begingroup$ Only a valve that blocks fluid going in $\endgroup$ Aug 2, 2020 at 10:53
