Here are my calculations. Am I doing anything wrong?enter image description here
  • 3
    $\begingroup$ Your ecu might be limiting the torque in first gear. Try again in second gear. $\endgroup$
    – Phil Sweet
    Jul 25, 2020 at 4:31
  • $\begingroup$ What about torque produced by the engine? Some cars are available with different engines which develop more or less power. $\endgroup$
    Jul 25, 2020 at 5:14
    $\begingroup$ You ignored the torque required to accelerate the rotating parts of the engine and transmission, and the wheels of the car. (That includes everything, not just the engine flywheel - crankshaft, camshaft, water pump, transmission drive shafts, etc...) $\endgroup$
    – alephzero
    Jul 25, 2020 at 11:24
  • $\begingroup$ alephzero, yup you're right. If I try this in a higher gear at a higher speed then the effect of these factors will be reduced. Right? $\endgroup$
    – Ardalan G.
    Jul 26, 2020 at 7:18
  • $\begingroup$ Phil Sweet, will do. Thx for the tip $\endgroup$
    – Ardalan G.
    Jul 26, 2020 at 7:19
