I need to select a solid body in ANSYS Design Modeler, with script, in a design with multiples bodies. With the following command I select all the solid bodies, but this is not what I need.
ag.bodyPick;
ag.gui.SelectAll();
I'm creating a script to model two spur gears engaged, first creating one tooth then making circular pattern to create the entry gear, with the following script I create the pinion but when I'm going to make the circular pattern for the gear, the pattern command give me an error, because I select all the solid bodies including the pinion, and I need to pick only the solid of the gear tooth to make the circular pattern them.
This is my script:
ag.m.ClearAllErrors();
ag.gui.setUnits(ag.c.UnitMillimeter, ag.c.UnitDegree, ag.c.No);
var p = new Object();
//Plane
p.Plane = agb.GetActivePlane();
p.Origin = p.Plane.GetOrigin();
p.XAxis = p.Plane.GetXAxis();
p.YAxis = p.Plane.GetYAxis();
p.Sk1 = p.Plane.NewSketch();
p.Sk1.Name = "Pinion";
p.Sk2 = p.Plane.NewSketch();
p.Sk2.Name = "Wheel";
//PINION
with (p.Sk1)
p.Sp1 = SplineBegin();
with(p.Sp1)
SplineFlexibility = agc.Yes;
SplineXY(-1.76564478418, 24.6869398366);
SplineXY(-1.51020858813, 24.7038816792);
//......... spline coordinates of the pinion profile
//......... removed because character limit
SplineXY(5.26099091644, 24.1843849328);
SplineFitPtEnd();
p.Ln2 = Line(-1.76564478418, 24.6869398366, -1.24843570599,17.4554120057);
p.Ln3 = Line(3.71989256718, 17.1000701545, 5.26099091644, 24.1843849328);
p.Cr4 = ArcCtrEdge(
0, 0,
-1.24843570599, 17.4554120057);
p.Ext1 = agb.Extrude(agc.Add, p.Sk1, agc.DirNormal, agc.ExtentFixe, 34.0, agc.ExtentFixed, 0.0, agc.No, 0.0, 0.0);
agb.Regen();
var PF1 = ag.gui.CreateSpot();
ag.listview.ActivateItem("Type");
ag.listview.ItemValue = "Construction Point";
ag.listview.ActivateItem("Definition");
ag.listview.ItemValue = "Manual Input";
ag.listview.ActivateItem("FD8, X Coordinate");
ag.listview.ItemValue = "0";
ag.listview.ActivateItem("FD9, Y Coordinate");
ag.listview.ActivateItem("FD10, Z Coordinate");
agb.Regen();
var PF2 = ag.gui.CreateSpot();
ag.listview.ItemValue = "34.0";
agb.Regen();
var LF1 = agb.LinePt();
LF1.AddSegment(PF1.GetPoint(1, 0),PF2.GetPoint(1, 0), 0);
agb.Regen();
var Pat = ag.gui.CreatePattern();
ag.listview.ActivateItem("Pattern Type");
ag.listview.ItemValue = "Circular";
ag.listview.ActivateItem("Geometry");
ag.bodyPick;
ag.gui.PickFilter(5, true);
ag.gui.PickFilter(11, false);
ag.gui.SelectAll();
ag.listview.ItemValue = "Apply";
ag.listview.ActivateItem("Axis");
ag.edgePick;
ag.gui.SelectAll();
ag.listview.ActivateItem("FD2, Angle");
ag.listview.ItemValue = "16.3636363636";
ag.listview.ActivateItem("FD3, Copies (>0)");
ag.listview.ItemValue = "21.0";
agb.Regen();
//GEAR
with (p.Sk2)
with(p.Sp1)
SplineXY(1.9304744152, 30.2623156532);
//......... spline coordinates of the gear profile
SplineXY(-5.79031304774, 30.3548985987);
SplineFitPtEnd();
p.Ln2 = Line(1.9304744152, 30.2623156532, 0.209834175566,173.751999593);
p.Ln3 = Line(-0.629381853016, 173.762062957, -5.79031304774, 30.3548985987);
p.Cr4 = ArcCtrEdge(
0, 191.250741537,
0.209834175566, 173.751999593);
p.Ext2 = agb.Extrude(agc.Add, p.Sk2, agc.DirNormal, agc.ExtentFixe, 34.0, agc.ExtentFixed, 34.0, agc.No, 0.0, 0.0);
var PF3 = ag.gui.CreateSpot();
ag.listview.ItemValue = "77.5";
agb.Regen();
var PF4 = ag.gui.CreateSpot();
agb.Regen();
var LF2 = agb.LinePt();
LF2.AddSegment(PF3.GetPoint(1, 0),PF4.GetPoint(1, 0), 0);
agb.Regen();
ag.bodyPick; //<- Here is where I need to select only the gear body
ag.gui.SelectAll();
ag.edgePick; //<- Here is where I need to select only the gear rotation axis for the circular pattern
ag.gui.SelectAll();
ag.listview.ItemValue = "2.74809160305";
ag.listview.ItemValue = "130.0";
agb.Regen();
