The shortest connection between two portals would be a tunnel with constant gradient. Why do long tunnels instead rise from both portals to a culmination point, introducing unnecessary steep gradients?
Some thoughts: If it is for drainage, this could as well be done to one portal only. Shortening of service tunnels cannot be a reason, as they are often not connected at the highest point. Problematic bedrock could as well be circumnavigated laterally.
