I need to invent a construction based on standard square tubes with holes placed in certain distance from each other and from ends of the tubes:
I also need to imagine the tube with holes as a parametric part. Therefore I want to base all the holes on alone sketch line with points, something like the following:
How can I base all the tube holes on the above sketch line?
  • $\begingroup$ Can you specify what you mean with "base all the holes"? What is missing in the second picture that you cannot use it like that? $\endgroup$ Jul 7, 2020 at 7:42
  • $\begingroup$ @OpticalResonator I mean that every point on the line should produce 4 holes on the tube. I can make the second picture, but I cannot make the first picture using the second. $\endgroup$ Jul 7, 2020 at 10:36
It feels a little unintuitive, because the part is a square tube, but you can use the function Circular pattern. Select the holes on one plane as elements to repeat, select 4 repetitions and as turning axis the axis along the tube, then the holes get placed in the desired fashion.
  • $\begingroup$ A also wanted to know how can one easily project such a line to all 4 faces, but the way you described is enough to make the holes I need, thank you $\endgroup$ Jul 7, 2020 at 13:18
  • $\begingroup$ This sounds good. To make the answer more complete, it could mention how a sketch driven pattern makes sense for the first plane, to make it as robust as possible. Then circular pattern the sketch driven pattern to the other faces. $\endgroup$ Jul 8, 2020 at 21:56
