I see that buildings in the developed part of the world have basements. Why?
But, I never see basements in most buildings in South Asia. Why?
Sign up to join this communityI see that buildings in the developed part of the world have basements. Why?
Basements are not that common in domestic properties. As posted in comments they are mostly found in areas where the ground freezes in winter. In the UK and Ireland some older properties have cellars as opposed to basements which were historically used for storage of coal etc. In the US the biggest reason why houses are built on basements in areas such as Colorado and the Northeast is to get the footings for the house below the frost line, which can be 3 ft. or 4 ft. down. The logic is that if you’re digging that deep, why not put in a floor and use the space? With no danger of frost in much of California, Texas etc, foundation footings don’t have to be nearly that deep. As for getting extra storage space, it’s generally cheaper to build at ground level, unless real-estate prices are extremely high where you want to build. You can, of course, include a basement in your floor plans anywhere, but if you have a flat site, I’ll bet that nine out of ten contractors will try to talk you out of it. Most of them do not want the worry of waterproofing a basement.
