I have question-related to industrial management, actually, it is a problem on arrow on activity network diagram. I tried to solve the question my self, below are the images. If I did any mistake kindly let me know.
Question: enter image description here
The duplicate activity H should start from the end of activity G.
otherwise you are stating that the duplicate of H can only start once H is completed...
The duplicate of activity K starts from the end of activity F.
When checking these diagrams, you just have to read the story in the diagram back to match the information in the table. If you list some of those paths you find you have:
ABEGHIJ
ABEGHHMN
ABCFKL
ABCFKKMN
And that is the issue, this is what you should have:
ABEGHMN and ABCFKMN
  • $\begingroup$ Thank you for your time. Actually the activity M is dependent on H and K. When h is complete and k is complete then i can start M. But you are suggesting what i understand -> start activity M when G and F are completed $\endgroup$ – Saad Zahoor Jun 21 '20 at 12:24
  • $\begingroup$ @saadBinZahoor no, I did not suggest that, re-read the answer. $\endgroup$ – Solar Mike Jun 21 '20 at 12:25
  • $\begingroup$ ok, d is actually a dummy activity. Secondly, let say if i start activity M from the end of activity G and end of activity F. Doesn't it means that activity M is staring after the end of activity G and F? But in question it says M can only start after K and H are completed. $\endgroup$ – Saad Zahoor Jun 21 '20 at 12:32
  • $\begingroup$ @saadBinZahoor read the answer. The dummy H starts when G finishes (as stated in the answer) and M can start once H is complete. Same for K. $\endgroup$ – Solar Mike Jun 21 '20 at 12:34
  • $\begingroup$ So should i make the diagram like this ibb.co/fYzxgwJ $\endgroup$ – Saad Zahoor Jun 21 '20 at 12:43
