I have data:
mass = 740 kg
wheel diameter = 670 mm
Rw = 0,335 m
power (max?) = 750 horsepower (551kW)
Now I would like to calculate car acceleration when throttle is max and speed in this moment = 100 km/h = 27,78 m/s
I calculate wheel RPM from this:
wheel speed(RPM) = v(km / h) * 25 / (3 * pi * r(m))
I get
WHEELrpm = 100 * 25 / (3 * 3,14 * 0,335) = 792
Next I calculate engine rpm:
RPMengine = RPMwheel * idifferential * igearbox * iclutch
where:
iidifferential  = 3,42
iclutch = 1
igearbox (gearbox ratio) = 2,55
RPMengine = 792 * 3,42 * 2,55 *1 = 6907
next I calculate torque from:
torque = (POWER * 5252) / rpm
I get
torque = (750 * 5252) / 6907 = 570
And now, apart from the resistance, I want to calculate drive force and acceleration.
I found this:
Fdrive = torque * gearboxRatio * iidifferential  * n / Rw
n - transmission efficiency (0,7?)
But I wonder if I can use it considering previous calculations. How to correctly calculate the acceleration now?
I try to base on this: https://engineering.stackexchange.com/a/22021 but I dont understand this formulas
  • $\begingroup$ acceleration is a change of velocity but you fixed that at 100km/h $\endgroup$
    Jun 19, 2020 at 15:04
  • $\begingroup$ I mean this is speed at this specific moment of time $\endgroup$
    – Mlody87
    Jun 19, 2020 at 15:14
You are fine. I'm not checking your work, but if you know engine torque, the using gear ratios you can calculate torque at the wheel. Force at the road is torque divided by wheel radius, and then A = F/M
This site is temporarily in read-only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
