Ηere is an open-loop transfer function and specifications for compensator design.
I defined the required poles and defined the angles according to the normal procedure of the root locus method and determined the zero and pole of the lead compensator. It led to
$$ G_c(s) = \frac{s+0.0345}{s+1.923} \cdot \frac{4 \cdot 10^{-7}}{s^2(s+0.5)} $$
and $K = 122874$ but as the question says settling time and percent overshoot cannot be satisfied as the same time with the compensator I just mentioned. Here is the code in MatLab
s=tf('s')
g=4*10^(-7)/((s^2)*(s+0.5));
gc=122874*(s+0.0345)/(s+1.850);
step(feedback(g*gc,1))
what is the reason?
