I'm trying to drive an aluminium plate using a motor via a 20mm-wide 2mm-thick stainless steel tube. The tube is driven by a 6mm motor shaft via a pulley and the torque will be around 5Nm at most. Is it a good idea to attach the plate to the tube with a split collar like this?
However it's not clear what the rated torque and axial force are. If this isn't a good way, what might be an alternative without welding or adhesive?
  • $\begingroup$ This looks pretty typical to me. But without details of what the plate is doing, what forces it will see, what your bearing arrangement is, a data sheet for this part etc, we can’t help much more... $\endgroup$ – Jonathan R Swift Jun 8 '20 at 16:41
That might be overkill in your application (but I don't know).
Figure 1. A random rigid flange coupling from an image search.
A rigid flange coupling may be a more economic choice if it suits.
From the comments:
What are the benefits of a rigid flange compared to a split flange beside costs? Doesn't the flexible coupler give more friction?
A flexible coupler is something different. A split collar is also something different to your picture which is, as far as I know, a taper lock flange coupling. The latter will be better in that it will be self-centering, give even grip around the circumference and over a length of shaft.
  • $\begingroup$ Right. What are the benefits of a rigid flange compared to a split flange beside costs? Doesn't the flexible coupler give more friction? $\endgroup$ – John M. Jun 8 '20 at 20:34
  • $\begingroup$ See the update. $\endgroup$ – Transistor Jun 8 '20 at 21:23
There are dozens of ways to connect to the shaft of a motor, A few examples:
  • set screw/grub screw
  • through taper pin
  • interference fit
  • split ring
  • taper lock
  • welded
  • keyway & key (most common industrial use)
Each of these has a torque spec that I think you can find in a mechanical engineer's handbook. There are probably decades old free ones on the internet which are fine. These are not new technologies.
