Pressure drop across a porous medium can be described by the Forchheimer extension to Darcy’s law: $$-\frac{dp}{dx} = \frac{\mu}{K_1}\cdot v + \frac{\rho}{K_2}\cdot v^2$$
where $K_1$ and $K_2$ are permeability coefficients that depends on medium geometry (Pitz-Paal et al., 1996).
I just came across this paragraph in a paper studying the flow stability in porous media in solar volumetric receivers, which I couldn't digest at all:
In the flow through a porous sample, the mass flow density is determined by the pressure difference between the two sides of the sample. The pressure drop is produced by a blower. Instability occurs when a pressure drop causes different mass flow densities
What blower? and what makes pressure drop cause different mass flow? (Keeping in mind previous equations)
