Assume we have a pipe with a diameter of 10mm. Water is flowing through that pipe and we know that the water pressure at the 'open' end of the pipe is 2 atm. How would one go about calculating the flowrate of water? Reasonable assumptions are allowed.
I at first thought of using Poiseuille's equation, but that requires you to have a container length. Right now I have found no way to calculate flow in my situation.
