Hacksaw blades cut on the pull stroke (back into the machine) and are supposed to lift on the push stroke, all the DIY setups I have seen cut on both the pull and push stroke, i.e.
What type of setup would allow you lift ever so slightly on the push stroke? Alternatively, are power hacksaw blades bi-directional? All help appreciated.
  • $\begingroup$ Unless the blade has teeth pointing both ways the blade only cuts in one direction. $\endgroup$ – Solar Mike May 29 '20 at 17:59
