I don't understand p 24 of this PDF from Rystad Energy. Can someone please distinguish, and ELI5, 7 ((Crude supply (current OilMarketCube, downside risk)) and 8 (Crude supply (with required shut-ins to balance))?
1 Answer
The precise definition of Oilmarket cube will be explained elsewhere, earlier most likely, but it will be a unit that is used to compare sources much like kWh can be used for gas as a cubic foot of gas varies its heating power with temperature.
It could be 1m^3 or 1000m^3 but it will be an amount stated.
