enter image description herethe wood texture is an overlay, underneath is plastic
If sanded it takes the face of the plastic off. Im looking to round the sharp corners.
the idea i'm working from now is using the same sharp corners , putting a 90 degree angle aluminum moulding piece , either using super glue to hold it to the box (not preferable) or using rivets to hold it in place. The panels are 7 mm thick.
i appreciate any feedback, suggestions on this . looking to keep the box together and then round the corners so that it's no longer sharp.
  • 3
    $\begingroup$ The title of your post suggests that this is a CAD problem. The post suggests that you have completed the build and you are now trying to modify the physical object. You have tagged it as "structural engineering" which means that it is about building structures. This is a mess. I think you should edit the question, remove the irrelevant information and tags and add a photo. Also explain why you want to round the corners and then put something over them. $\endgroup$ – Transistor May 16 '20 at 8:24
  • $\begingroup$ i appreciate the feedback and suggestion. It was understood and adjusted @Transistor $\endgroup$ – EmpireLearning May 16 '20 at 8:49
  • $\begingroup$ The title still mentions "inventor CAD" which I presume is meant to be "Inventor CAD" (Autodesk Inventor). (Capitals matter.) But it's not clear what CAD has to do with the question as applying a fillet or chamfer to the corners is a trivial task in most solid modelling CAD programs. $\endgroup$ – Transistor May 16 '20 at 9:35
  • $\begingroup$ You might be looking for cabinet+ball+corner+fittings. $\endgroup$ – Transistor May 16 '20 at 9:38
    $\begingroup$ OK, I'll post it as an answer so you can mark the question answered. I still have no idea what this has to do with any kind of CAD. $\endgroup$ – Transistor May 16 '20 at 18:18
You might be looking for ball+corner. (Use the image search.)
Figure 1. Ball corners are commonly used on flight cases for musical instruments, band equipment and scientific or engineering equipment.
