I know that a gear reduction would decrease the RPM if the motor ran at constant speed, but in reality its speed is a function of the load.
I first tried turning a wheel with a direct drive system, but the motor started getting warm (burning off the lubricant inside) and was spinning much slower than without a load because it didn't have the torque required. I know that a gear reduction would cause less stress (torque) on the motor, which in turn, would allow it to [possibly] go faster. I am essentially looking for the highest speed I can get, so how would I determine the proper gear reduction ratio to use?
