This source describes in detail a formula used to calculate the airflow requirement in order to cool a computer system.
$$Q = \dfrac{P_{loss}}{c_p \cdot \rho \cdot \Delta T}\cdot k$$
Clearly, the higher the packing density (k) the higher the airflow requirement.
From the same source:
The k constant describing the packing density (concentration) of the components that prevent the free flow of air (k=80-95 rare placement, k=60 dense components)
k = 60 for high component density (ultra small pc)
k = 85 for low component density (spacious full tower)
Meaning a small crammed PC case full of high-end components needs less airflow to be cooled than a spacious tower with the same high-end components. At this point, things make no sense. It should be like this:
k = 60 for low component density (spacious full tower)
k = 85 for high component density (ultra small pc)
60 = low, 85 = high
Do you think it's a typo?
EDIT
In this chart from the same source the airflow is lower with higher density components:
