My house has several transfer grilles like this:
Transfer Grille
Except they have no baffles inside them, so light and sound come through into our bedrooms quite easily. I'd like to put in a sound maze like this to block light and sound:
Sound maze
My concern is that I will be restricting air flow enough to impact the HVAC system's effect on these rooms when the door is closed. Is that a valid concern, and if so, what considerations should one make to maximize air flow through a sound maze like this?
Yes, it is definitely going to impede the circulation of air. The fan of the HVAC blows the air very gently, so much so that for a large room one register maybe not enough.
For blocking the light you could try hanging a small drape 12 inches in front of the grill.
If the noise is really a nuisance the only effective solution is to connect your grill directly vis a flex duct to the HVAC system.
You can hide it in a cosmetic soffit.
  • $\begingroup$ I'm trying to get a sense for how much it would impede the circulation of air. A little bit is acceptable, but a more than 50% air flow reduction would be a bad outcome. My understanding is that the air would flow faster through a smaller opening, but then friction and turbulence would reduce the volume of air flowing. I'm trying to figure out to what extent these things offset each other. $\endgroup$
    – John
    Apr 24 '20 at 14:17
