I have an assembly in Solidworks with gears that I want to make a sketch from it. I want to hide the gears teeth and represent the each gear teeth only as center line, like in the picture below on the left:Taken as an example from https://www.cad-notes.com/automate-standard-additional-notes-in-the-drawing/amp/
I have tried every button in Solidworks, but didn't find how to hide the unnecessary tooth at the end.
Thanks for any help.
  • 4
    $\begingroup$ You could make a configuration of the component with the teeth suppressed and the OD adjusted to the centreline $\endgroup$ Apr 21, 2020 at 10:42
  • $\begingroup$ Thanks, I thought about it, but I've been told that there is a button for it, I guess the person lied to me. $\endgroup$ Apr 23, 2020 at 7:05
