I am not an engineer, but I thought maybe this could be a very old and classic problem in structural/mechanical engineering. I need to build a support structure to hold a uniformly-distributed load of 75 kg (which has the shape of a square box). I can only use pipe and welding (or bolts+nuts). The only force it needs to hold is the weight of the box, there are not lateral forces expected (it will be placed indoors on a hard, level surface and will not be pulled/pushed from any of the 4 sides).
I wonder if there is a relatively well known and simple answer to these 1) what is the strongest structure possible? 2) what is the optimum case in terms of strongest structure possible using a minimum amount of pipe?
I drew a few options (front and side views) but I guess there could be many more and a large amount of combinations. Is this a well-known case? or maybe it doesn't matter much given the relation between the strength of the steel pipe and the "small" load?
The distance between the floor and the bottom of the box is 70 cm. The box is 65x65x22 cm thus the pipe structure view from above is a 65x65 cm square (or that's how I would initially imagine anyway).
