Heat pump cost 2-4 times lesser of energy to heat than non-heat pump heater, then why are non-heat pump heater still very common ?
(1) At home, boiler and water radiator is used.
(2) For district heating, central boiler is used.
Why aren't most these replace by heat pump?
For (2) the reason may be there is not enough heat source to pump from to support megawatts of power output.
Possible reasons for home: heat pump is driven by electricity and boiler cost lesser then electricity, then the cost difference is not that much.
I also heard in cold winter air conditioner won't work well as heat pump, is this true and is this a possible reason?
4 Answers 4
The last one is the reason furnaces are still nearly universal where temps drop down to below freezing. People will run an air source heat pump usually down to an outside temp of 40 F, at which point they become very inefficient and require a defrost cycle. Below that, the furnace has the needed capacity and operates cheaply. Water or ground source heat pumps can run in colder weather, but there is about a three month time lag on ground temperature vs air temperature, so even these need a short winter to be viable on there own, else they run terribly in the spring.
  • $\begingroup$ en.wikipedia.org/wiki/Air_source_heat_pumps, it says air heat pump work well for <0C $\endgroup$
    – jw_
    Commented Apr 23, 2020 at 9:01
  • $\begingroup$ @jw_ yes, at a cop way below 3 or 4, like under 2 which means they are not being very efficient. As I live at over 1000m above sea level in the Alps and work with people who install heating systems of all types I can promise you that they tend to avoid installing air based heat pumps above 1000m, however, heat pumps that are ground source are often used as the temperature below ground (deeper than 2m) is around 5 to 8 degrees C all year round. $\endgroup$
    Commented Apr 23, 2020 at 9:58
  • $\begingroup$ Yes pvhvac.com/blog/heres-the-truth-about-dual-fuel-heating, really nice article, make everything clear $\endgroup$
    – jw_
    Commented Apr 30, 2020 at 13:02
  • $\begingroup$ @jw_ Wiki article says at $0^oF$ COP is 1 for most units. That is it works as well as regular electric heat. $\endgroup$
    – Rich
    Commented Apr 13 at 4:13
In most cases, heat pumps are used for heating, at least where I am. They take low grade heat from the atmosphere or underground and use that to heat dwellings. Some are reversible to cool buildings in the summer.
Why aren't they more common? well that depends on many factors: what is there already, what the owner is prepared to pay, how much time is available for replacement if the old unit has failed etc etc
I installed a « puit canadienne » for the incoming ventilation air and as the ground temperature is relatively constant at a 2 metre depth (approx a 3 or 4 degree C change yearly, compared to a 30 degree change for the surface) this help moderate the incoming air both summmer and winter.
TLDR: because historically, gas was cheaper still. Also, "but sometimes!" requirements to work during polar vortex weather, require more innovation than US manufacturers can be bothered to do. Foreign units do it just fine.
It's about social resistance and manufacturing ramp-up
It's largely about social beliefs and varies a lot by country.
Look at the coverage of the Ukraine war of any of their high-rise apartment blocks. They are festooned with mini-split outdoor units. This is a poor country with a \$4000/year (\$333/month) per-capita GDP pre-war (I'm not using PPP because these units are foreign-made). And mind you, those tower blocks are in cities with district heating. The mini-split is there for supplemental heat and A/C, so they are comfort/luxury items.
But conversely you have the USA where "methane furnace, forced-air, with That 70's non-reversable A/C added to the air handling stack" is the gold standard - and I've shopped for HVAC and it's a nightmare trying to talk contractors into selling you anything else. There is a tremendous inertia in that sense - HVAC contractors discourage it so buyers don't buy it so contractors don't learn the tech so nobody's good at it so nobody recommends it, rinse wash repeat.
You're clearly talking about a country older than USA or Canada. But it's the same political and manufacturing inertia.
However, for some reason, suddenly on February 24, 2022 everyone wanted a heat pump at the same time. Manufacturers can't just "flip a switch" and massively increase production - think of all the supply chain problems of the last 2 years. They can't even do it with 152mm artillery shells, which are easy by comparison to a heat pump.
Actually, hydronics is an opportunity!
A great resistance to heat pumps in territories with home boilers or district heating is that the hydronic lines for the water radiators are built into the walls typically and not easy to service. A regular question is "can those existing lines be used for refrigerant" in a mini-split type system and the answer is "no".
However, I have enjoyed use of an amazing technology that makes full use of boilers and district heating. The system circulates "service water" exactly as it does currently. But instead of dumb radiators, water-air heat pump units are installed. In winter, the heat pump "radiator" takes from the warm water (which need only be 30-40C/body temperature) and extracts heat to fill the room, returning cold. This is how the system works already just normally at much higher temperatures with higher return temperatures as well. Having lower supply temperature means lower distribution losses.
But by summer, the heat pump "radiator" takes cool water (which can be 20-40C/70-110F or so) and pushes heat into the water to cool the room. For this to work, one modification is made back at the boiler or district heating facility. When the water arrives hot, it is directed into outside radiators -- or at large scale, cooling towers.
So in fact, this is a case where district heating certainly will scale to work with heat pumps in both heat and A/C modes. The only problem with these units is they contain the refrigerant compressor on-board. That makes them louder than one might prefer.
Sure. That's a problem. If you have a compact district heating plant inside a city, and you try to make it an air sourced heat pump, they're going to name the plant "Elsa"! It will be a virtual tornado of air flow, blasting the city for blocks around with very cold air - which will partially defeat its purpose, as everyone's homes will get colder and that will increase heat demand! No, a better way is needed.
But did you catch the part where heat pumps at the home radiator only need service water that is 30-40 degrees C? That is much easier to transport long distances. Consider a power plant 50km (30 miles) from the city center. It has plenty of 90C discharge water, useful locally, but it will cool off too much if shipped 50km. Heat pumps wipe out that problem. As said, an in-home heat pump "radiator" can make good use of 30-40C service water. And if updating every radiator in the district is not possible, the district heating plant itself could contain a very large heat pump, which extracts heat from the tepid power plant water, and makes 90C service water for distribution into existing infrastructure.
Similarly, if tepid deep groundwater could be obtained in sufficient quantity, that could serve the same purpose.
Modernizing all the radiators is best, because it allows lowering service water temperature to 30-40C, and that means anyone can select heat or A/C at their pleasure.
Cold weather, though?
Not anymore. Cold-weather heat pumps have gotten really good.
https://www.youtube.com/watch?v=MFEHFsO-XSI
Technology Connections studied the viability of heat pumps in Chicago, where the westerly winds tend to mean Chicago does not benefit from lake effect. They did extremely well - modeling against the 2019 Polar Vortex winter, being over-unity at all times, and beating "the benchmark" all but 141 hours. See 10:52 here.
Being written days into the Ukraine invasion, "the benchmark" was seeking maximum fuel-efficiency using entirely methane, either in an electricity plant or in-home methane furnace. 250% heat pump efficiency was deemed the breakover point where burning the gas at the power plant was more efficient.
However, the perception that heat pumps do not work in the cold will continue to be an impediment.
I installed an 18SEER heat pump when I moved into this house. Compared to the cost of oil it beat it hands down to 5F, but at 5F it didn’t produce enough heat to keep the house warm - so the oil went on.
Usually heat pumps come with additional direct electric heat for the times when output from heat pump cycle is insufficient, but then you’re paying for electric heat, which is the most expensive.
When I had the chance I had natural gas installed. Added a high efficiency heat/hot water tankless boiler and installed a hydronic coil where normally the additional electric heating coils would go in the heat pump. (Did all this work myself) With natural gas price so low, it’s cheaper to use gas heat up to about 53F! (see below) I keep an excel file handy so as the gas and electric prices vary I can adjust the temperature at which gas heat comes on.
There you see the problem with heat pumps; as the outside temperature drops they provide less heat and have a lower COP (like efficiency, but not), so you need an additional heat source, which most times is simple electric coils, that being easiest to install.
Here's a graph of my latest analysis:
relative cost of gas vs heat pump with temperature
Here's a graph of performance for my two ton unit: (from manufacturer's data)
