I am reading a report titled ``Definition of safe separation criteria for external store and pilot escape capsules'' in which the author uses following expressions.
From Newton's second law: $$ z \left( t\right) = \frac{1}{m} \int \int\limits_{0}^{t}F \left( \tau \right)d\tau dt$$
From Taylor Series,
$$ F \left(\tau \right) = F \left( 0 \right) + \sum\limits_{n=1}^{\infty} \frac{d^{n}F}{d\tau^n} \Bigg\rvert_{\tau = 0} \frac{\tau^{n}}{n!}$$
Substituting the Taylor series expansion in first equation, we get
$$ z \left( t\right) = \frac{1}{m} \left[ \frac{F \left( 0 \right) t^{2}}{2!} + \sum\limits_{n=1}^{\infty} \frac{d^{n}F}{d\tau^n} \Bigg\rvert_{\tau = 0} \frac{\tau^{n+2}}{\left(n + 2 \right)!}\right] + w \left( 0 \right) t + z \left( 0 \right)$$
Questions:
  1. I am familiar with differntial equation form of Newton's Second law, i.e., $F = m \frac{d^{2}z}{dt^{2}}$ but I don't know how the author obtained integral form, especially the limits of integration.
  2. Since the integral with respect to $\tau$ is a definite integral, why the author has added constant of integration when integrating with respect to $\tau$.
Review of Terms
w(t) -> v(t) -> velocity at time t
z(t) -> x(t) -> position at time t
w(0) -> initial velocity
Derivation
We can compute $w(t)$ from force, since $\frac{dw}{dt} = F(t) / m$, so $$w(t) - w(0) = \int_{0}^{t}\left(\frac{1}{m}F(\tau)d\tau\right)$$
Which means $$w(t) = w(0) + \int_{0}^{t}\left(\frac{1}{m}F(\tau)d\tau\right)$$
We can compute $z(t)$ from velocity: $$z(t) - z(0) = \int_{0}^{t} \left( w(\tau) d\tau \right)$$
Where we substitute the above integral expression for $w(t)$: $$z(t) - z(0) = \int_{0}^{t}\left( w(0) + \int_{0}^{t}\frac{1}{m}F(\tau) d\tau\right)d\tau$$
Since $w(0)$ is constant, we can compute its integral in closed form: $w(0) * t$.
$$z(t) = z(0) + w(0)t + \int_{0}^{t}\left(\int_{0}^{t}\frac{1}{m}F(\tau) d\tau\right)d\tau$$
And you can use that Taylor expansion to write an expression for this integral.
Conclusion
  1. The integral form is the double-integral of the differential equation.
  2. The integration constants you are seeing come from the fundamental theorem of calculus — they’re the initial conditions. Recall the classic kinematic equation: $z(t) = z(0) + w_0t + \frac{a_0t^2}{2}$ for the same expression, where acceleration is known to be constant. $w_0$ is $w(0)$. The body’s initial velocity applies a linear offset to its motion
I have never seen such an expression of the Newton second law. From the first equation you provide, it seems that there are two different time variables, $t$ and $\tau$, which is obviously not the case. From what I get this notation is just a translation of a double integration in time. I agree with you that the limits of the integration are quite confusing. To my mind both integral limits should be 0 and t, and I would rewrite the whole equation this way: $$ z \left( t\right) = \frac{1}{m} \int\limits_{0}^{t} (\int\limits_{0}^{t}F \left( \tau \right)d\tau) d\tau $$ As for your second question, the constants of integration just reflect the physical initial conditions. $w(0)$ is the velocity and $z(0)$ the position at time $t=0$, I do not think it has something to do with the integral being definite.
  • $\begingroup$ I think integration constants are not added when evaluating definite integrals. Thanks. $\endgroup$ – Ali Baig Apr 14 '20 at 9:37
