I would like to perform several FEM simulations on a given mesh with ABAQUS, where only the orientation of an element set would change in between.
Currently, I'm just generating several inp files (see an example below) and I run them one after the other. But this has the inconvenience to reload every time the mesh, which takes time due to its large size.
Would there be a way to load the mesh only once, perform the simulations, save the results in a file, modify the orientation (orientation label going from ORI_1 to ORI_X), reperform the simulation, save in another file and so on?
I thank you in advance, Regards, R.B.
*HEADING
TEST
*INCLUDE,INPUT=Mesh.inp
*INCLUDE,INPUT=PARAMETERS_MATRIX.inp
*Solid Section, elset=AllE, material=Matrix, ORIENTATION=Matrix
*INCLUDE,INPUT=PARAMETERS_CRYSTAL.inp
*INCLUDE,INPUT=ORIENTATIONS_LIST.inp
*Solid Section, elset=MID, material=CRYSTAL, ORIENTATION=ORI_123
*Step, NLGEOM=NO, name=Step-1
*Static
1., 1, 1e-05, 1.
*INCLUDE,INPUT=MESH_BC.inp
*Output, field
*element output, POSITION=CENTROIDAL, elset=AllE
S,E,EVOL
*End Step
Easiest way would be creating n no of input files with orientation corresponding to orientation_i with the help of some programming language and run all of them as a batch either with a simple python script or directly in the command prompt.
For example the python script would be,
myJob1 = mdb.JobFromInputFile(<jobName>, <inputFile_i>)
myJob1.submit()
myJob1.waitForCompletion()
Repeating this n of times as required save as a python script and run it inside Abaqus CAE.
Or in command prompt,
abaqus job=<inputFile_i> interactive
over n times
Another way would be using *PARAMETER keyword available in Abaqus.
For more information, look at PARAMETER keyword and JobFromInputFile in abaqus documentation.
