V is a rotation factor to account for the difference in ball rotations for outer ring rotation vs. inner ring rotation.
V = 1 for inner ring rotation V = 1.2 for outer ring rotation
From Shigley's Mechanical Engineering Design - Ninth Edition
What is the reason behind this?
Figure 1. Source: Wikipedia's Ball-bearing.
The distance rolled on the inner ring is the same as the distance rolled on the outer ring. Due to the difference in circumference the ball will pass the same point on the inner ring about twice as often as it passes the same point on the outer ring (for these dimensions).
