Essentially I have a 100 lbs. pile driver with an eyelet for lifting it on top. (It's on rails) I want to set up and automated machine to lift and drop the driver at a variable pace. Preferably I would like to use a cheap electric motor. I can use pulleys, and/or a block and tackle system to reduce the amount of work the motor needs to do. I can route/3D print materials if need be. I have looked at mechanical systems and setups all over the internet, but have yet to find a simple effective solution for what I am trying to do.
  • $\begingroup$ A cam would be one possibility. $\endgroup$
    Apr 3, 2020 at 22:11
    $\begingroup$ How high is the lift, how often, and for how long? Block and tackle doesn't change the amount of work; it just changes the rate at which it gets done. $\endgroup$
    – Dave Tweed
    Apr 4, 2020 at 1:11
  • $\begingroup$ Agreed. The specification is incomplete. $\endgroup$
    – Transistor
    Apr 4, 2020 at 8:53
  • $\begingroup$ 100 lbm =~ 45 kgm. Wattage =~ kg x metres_vertical x 10 / time_seconds. So per metre of head power = 450 Watts/ seconds to lift. A battery electric drill (or even a mains drill) with a "drum" driven by the chuck can be as low geared as you wish. You can also buy geared motors. || At say 120 RPM = 2 RPS (drill on low speed screw driving mode) say with a 25mm / 1: dia drum ~= 80 mm circumference = 160mm vertical/second = 6s for 1m lift so about 450/6 = 75 Watts. Say 100 Watts plus. Smaller dia drum = slower = less watts. Release could be electromagnet. Could use endless 'rope' with 'carriages'. $\endgroup$ Apr 4, 2020 at 12:00
100 lbm =~ 45 kgm.
So per metre of head,
power = 450 Watts / seconds_to_lift.
At say 120 RPM = 2 RPS (drill on low speed screw driving mode) say with a 25mm / 1 inch dia drum
Could use endless 'rope' with 'carriages' or return carriage each time.
A threaded rod driven by a drill or geared motor is also a potential low cost and 'not too hard" solution.
You can have your motor attached to a vertical chain rolling around 2 pulleys.
This chain with several brackets constantly moves a one hundred lbs metal ballast which is assembled on the shaft of your mechanical hammer and releases it on top.
It drops down repeatedly, banging you jack-hammer onto the job.
