I have a basic design of two arms which need to be brought together. But I tried the design using a test setup and it did not work successfully. Here is a diagram of my design - enter image description here
What I observed is that arm 2 moves up before arm 1. I want both of them to move towards each other to cause a compression, and away from each other to cause expansion. Is there any way in which that could be achieved using minimal design requirements?
  • $\begingroup$ Have the arms connected with gears at their pivot. $\endgroup$
    Apr 3 '20 at 12:28
  • $\begingroup$ @SolarMike: That's the same solution I was thinking of. Even if short and sweet it belongs in an answer, not a comment. $\endgroup$
    – feetwet
    Apr 3 '20 at 13:26
I can think of two options:
1) have the arms connected by gears at the pivot point - when one is moved so will the other, in fact one could be fixed...
2) connect the arms with a threaded rod (needs left & right hand threads) and use a pulley to rotate the rod - then the arms will move according to the pitch of the thread - actually 1 turn will move twice the pitch.
  • $\begingroup$ in both these cases, how will the rotation in any one direction, cause the arms to move in opposite directions? Could you explain that? Thanks $\endgroup$ Apr 3 '20 at 13:48
  • $\begingroup$ Think of a pair of calipers, some have a threaded rod (with left & right hand threads) which means they open and close with rotation of the rod. With gears if one move then the other moves... $\endgroup$
    Apr 3 '20 at 13:52
  • $\begingroup$ Thanks a lot! Makes sense, but just be sure, it will cause both the arms to move right? I.e none of the arms are stationary, because I want it to compress a material kept in the middle equally on both the opposite faces. $\endgroup$ Apr 3 '20 at 14:03
There are many ideas which have worked for different gears
like this drafting compass with a threaded shaft and a roller:
drafting compas
And this pantograph.
pantograph
You could try 2 bar linkages, it's basically what you're already trying but without a pulley and unequal displacement.
