I'm trying to understand in depth the behavior of progressive scan TV monitors (LCD/LED - Digital Television). From what we already know, the tv's screen scans the image row by row (as rolling shutter cameras does), sequentially from top to bottom. However, I would like to know a basic time schedule that can help me answer the following questions:
  1. What is the definition of the duration of the scanning of one row, and how is it related to the response time of the screen?
  2. Does the scanning of one frame happens before the previous frame scan ends? In other words, Does this scanning occurs in an overlapped manner between consecutive frames? Or there is a wait time between consecutive frames, so the screens holds one frame during a short amount of time before starting the transition to the next frame. In this case, what is the definition of that time?.
  • $\begingroup$ Are you asking about CRT (cathode ray tube) or LCD/LED (digital)? $\endgroup$ – Transistor Mar 23 '20 at 13:19
  • $\begingroup$ I think you need to fix your question then. If you're asking about TVs and eliminating PAL or NSFT (do you mean NTSC?) then that leaves SÉCAM. $\endgroup$ – Transistor Mar 23 '20 at 13:24
  • $\begingroup$ You might read Progressive scan and explain what parts you don't understand. It could save us a lot of typing. $\endgroup$ – Transistor Mar 23 '20 at 13:26
  • $\begingroup$ I was referring to the interlaced PAL and NTSC schemes. You are right. Sorry for the confusion. $\endgroup$ – CristoJV Mar 23 '20 at 13:30
    $\begingroup$ Then edit the original question so it is clear, do not leave important information in the comments. $\endgroup$ – Solar Mike Mar 23 '20 at 13:37
The question is still a little confused after the edits.
The subject is really only of interest because our new digital systems have to be able to receive an analog signal the format of which was entirely designed around the available display technology of the time. Interlaced scan was used on cathode ray tube (CRT) television to sort out a couple of problems:
  • The low frame rate gave a noticable flicker as the phosphors had faded by the time the next refresh came along.
  • Slower phosphors could be used but these gave increased motion blur.
  • Interlaced displays used a short-decay phosphor but drew the odd and even lines on alternate scans. The result was that all areas of the screen were partially refreshed at twice the frequency.
This is largely irrelevant for digital LCD/LED TVs as the display logic holds the pixels on from frame to frame without fading. The digital receivers now have to receive and digitise the analog transmissions for display on a matrix monitor.
Figure 1. The NTSC composite colour waveform. Source: Maxim.
The duration is simply the time it took for the electron beam to scan one line of the TV. As a rough estimate divide one second by the frame rate and again by the number of lines.
The system couldn't support an overlap. After all the horizontal lines were transmitted the relatively long vertical retrace pulse was given, the vertical deflection waveform was reset and the next frame began.
The digital display can be designed to do it in a number of ways. If it was me (and I know little about the topic) I would digitally buffer a full frame (both odd and even interlaces) in the graphics card and then have the graphics card output the frame in non-interlaced mode. Remember that each pixel will remain on until updated, unlike the fade-out of the CRT display.
