I am working on an acid filtration system and I need to be able to pressurize the effluent from the diaphragm pump such that the acid can be forced through a filter. I am not quite sure if a diaphragm pump can pressurize the influent and also be able to adjust the pressure. Can they do this? Or is there another pump that I should look for?
1$\begingroup$ I am confused by your wording, please clarify what is meant by "also be able to adjust the pressure". In general, a diaphragm pump is a constant volume pump that can raise the pressure of the fluid as it is discharged from the pump, as shown in it's pump curve. You can try to find a pump that outputs the needed pressure, or have equipment after the pump to adjust the fluid's pressure. $\endgroup$– J. AriMar 17, 2020 at 18:44
$\begingroup$ Okay, well that pretty much answers my question. I was not able to see the pump curve for the pump I want so I was unsure. $\endgroup$– JasonMar 17, 2020 at 19:43
$\begingroup$ Please accept the answer (that I just posted) so the question can be marked closed. $\endgroup$– J. AriMar 17, 2020 at 20:25
1 Answer
