I'm doing this special project where I have to make concrete using a Martian simulant provided from a commercial source.
I measured it as 500 grams initially, then submerged it in water for a day. It came back as 727 grams, meaning that it gained 200 grams of water, as it is now in its saturated surface dry state.
$$A = \dfrac{W_{SSD} - W_{OD}}{W_{OD}}\times100\%$$
Following this equation to measure the absorption value, it would mean that the value would be around 50%, which is very high. Usually, normal aggregates on Earth have an absorption rate of around 10%!
Is there anything that I may have been doing wrong? I am very skeptical of my results
