I am attempting to drive a device with a motor, but also require water input.
Is there such a device that serves as both a drive motor with a water pump through the motor's shaft?
In essence, it would have the functions of both a motor and a water pump in one.
  • $\begingroup$ Motors and pumps are often bolted together or share a common shaft. $\endgroup$
    Mar 8 '20 at 18:37
  • $\begingroup$ Are you trying to drive a device and a pump with the same motor along the same axis, or do you want to pump water through the rotational axis of the motor? I don't quite understand your requirement. Maybe a simple drawing? $\endgroup$
    – morbo
    Mar 8 '20 at 22:59
  • $\begingroup$ Yes, drive a continuous flow centrifuge with input/output slurry. Like, iCon 150 $\endgroup$
    – Simple Ape
    Mar 22 '20 at 2:16
