I'm using an NPN transistor to pull the gate of a P-channel FET low. I'm driving the base with 3.3v and a 10k series resistor. I have a 100k resistor in series with the collector and the gate of the P-channel FET which is then pulled up to 5.4v with another 100k resistor. So my base current is about 20x my collector current. Any trouble with that?
  • $\begingroup$ Are you aware of Electronics.StackExchange.com? $\endgroup$
    – Transistor
    Feb 28 '20 at 17:44
  • $\begingroup$ Kirchhoff's Voltage Law determines actual Collector current, so yes. $\endgroup$ Feb 29 '20 at 2:30
  • $\begingroup$ Can you please tell us the voltage at the upper end of R220 resistor? $\endgroup$ Feb 29 '20 at 19:10
  • $\begingroup$ @StainlessSteelRat I’m not sure how KVL answers my question, I think you mean KCL but that doesn’t tell me whether or not the transistor is conducting. That’s all a function of the transistors parameters. $\endgroup$
    – lusher00
    Mar 2 '20 at 13:41
  • $\begingroup$ @user8055 the top of R220 is 5.4v as stated in the original question. $\endgroup$
    – lusher00
    Mar 2 '20 at 13:42
Kirchhoff's Voltage Law (KVL) must be satisfied.
You are fixiated on:
$$ \beta = \frac {I_C}{I_B}$$
So $I_C$ must be larger than $I_B$, but this implies the transistor is operating in the active region.
KVL input side:
$$V_{BB} - V_{R_B} -V_{BE} = 0$$
$$I_B = \frac {V_{BB} - V_{BE}}{R_B} = \frac {3.3V - 0.7V}{10k\Omega} = 260 \mu A$$
KVL output side:
$$V_{CC} - V_{R_{C_1}} - V_{R_{C_2}} - V_{CE} = 0$$
$$I_C = \frac {V_{CC} - V_{CE}}{R_{C_1} + R_{C_2}}$$
If we assume $V_{CE} = 0$, we can get $I_{C_{Max}}$.
$$I_C = \frac {V_{CC}}{R_{C_1} + R_{C_2}} = \frac {5.4V}{100k\Omega + 100k\Omega} = 27 \mu A$$
So based upon biasing resistors, the maximum $I_C$ is 1/10 of $I_B$. Transistor is in the cut-off region.
  • $\begingroup$ This is not at all what I'm looking for. All you did was verify what I said to begin with, that the base current is much greater than the collector current. I also did that math and that's why I'm here asking the question. Your math just assumes the transistor is conducting which was my only question. $\endgroup$
    – lusher00
    Mar 3 '20 at 14:38
  • $\begingroup$ So what are you looking for. It is the math associated with your circuit. There is no need for 100k resistors. $\endgroup$ Mar 3 '20 at 14:43
  • $\begingroup$ Just a yes or no answer. Do NPN BJT’s behave as expected with very small collector current in comparison to the base current? I did the same math but it assumes the BJT is on. $\endgroup$
    – lusher00
    Mar 4 '20 at 15:46
  • $\begingroup$ No. If your transistor BE is forward biased, transistor is on, just no collector current. $\endgroup$ Mar 4 '20 at 20:22
As stated by @StainlessSteelRat the transistor is operating in the cut off region. Below is graph from the datasheet showing the relationship between $V_{CE}$, $I_B$ and $I_C$.
Vce Ib and Ic relationship for 2SC4617
References:
