Consider a transmission for a tandem rotor helicopter with two engines and two main rotors such as the one below.
Both engines are connected with sprag (one-way) clutches such that an engine's speed can underrun the rest of the system (e.g. engine failure), but normally they move in sync. The two rotors are always synchronized so they don't collide with each other as they spin (in opposite directions).
Let's assume that we know the moments of inertia for each engine and each rotor. There are accessories (not shown in the picture) which are driven by the same synchronizing shaft and there are of course mechanical losses, but we can neglect all those for simplicity. There is, however, a speed change between the engines and the rotors that needs to be taken into account.
In modeling this system, since each engine can underrun the rotors, I need to integrate the local accelerations to get the speed of the rotors and each engine separately. Generally, my question is: what torques and inertias does each "see" for the purposes for the purpose of finding an acceleration from unbalanced torques?
For the case that both engines are operating and driving (i.e. engaged clutches):
- Would each component (engine 1, engine 2, and the rotors collectively) "see" all four torques and all four inertias (the four being two rotors and two engines)?
- Or would each engine be unaffected by the torque and inertia of the opposite engine (i.e. due to the one-way clutch) and only "see" itself and the rotors (or maybe some portion thereof)?
For the case when an engine is being shut down and is no longer driving:
- Would the shut down engine only see its own inertia and small and diminishing torque (and then you'd have to add some losses to actually get it to decelerate)?
- Would the rotors "see" the torques and inertias of the rotors and the one remaining driving engine?
- What about the engine that's still driving - the rotors and itself?
